Did a log what do you think
Log only RPM, Timing, and O2. Also try playing with your byte timing to get a better sample rate.
Looks lean in the midrange as your timing is being pulled but it starts to come back up top.
what do you mean try playing with my byte timing whats that? and what do you think the casue is of why its lean?
thanks
Byte Rate is what he means, like how often the device records or looks at the readings and stores them like you only have 8 stored data readings, well if you turn the bit rate up on that same pull with the same amount of time you could have 12 or 14 readings or even 20 readings just how you set it. Do that do another pull preferably 3rd gear and AS FAR THEW THE GEAR AS POSSIBLE like start 2.8k and pull to 6.8k or even higher
  • Wanted 6 bolt NT water pipe
    • chrisman287
