HELP! Please, WISEMEN AND GURUS!!!
Status
Not open for further replies.
webshell
61
Jun 23, 2004
SPringdlae, Maryland
Hey I have a 95 GST with no mods with the exception of an intake and a MBC (14psi). After installing my MBC 2 days later i start my car drive, get into boost, and a huge cloud of white smoke comes out. Now its puffing white at idle and when i drive. I have done the following:
-compression is 164-160-160-164 (not done at operating tempetures)
-no oil in spark plug valley
-no oil than normal in piping, maybe a lil more
-sparkplugs are no blacker than im guessing they would be noramlly
-I hear this gurgulling/bubbling sound coming from the turbo wen i put my ear to the intake
-turbo has minimal in and out play if any, and side to side play is more than i had.
I think it would be a blown turbo seal somewhere letting coolant in and I think thats the noise im hearing.
PLEASE HELP ME, this is my only car.
Thanks.
Get a cooling system pressure tester and pressurize the system see if it holds, plus if there is any leaks you can watch for coolant. Even have the spark plugs out and look in the cylinder while you leave it pressurized. Plus you can look at the turbo and in it while system is under pressure if there is a coolant leak you will be loosing pressure and that stuff has to be going some and building up. when the motor is not running
Status
