Korndogg
- 471
- 0
- Jun 21, 2003
randolph,
Vermont
hey guys
i put my evo3 16G on last weekend, with 580's and a 190lph. (more details in profile)
i gave it the 500 recommended miles with minimal boosting, which i hit tonight
so, i of course brought it up to 19PSI (where i want it for now) tonight and started tuning a bit.
first of all, i adjusted my low-throttle by adding the STFT and LTFT and bringing them to zero. i was surprized to see that i ended up having to put my low-throttle settings at -9 all the way across the board on my safc2. doesn't that seem fairly rich for 580's?
anywho, this is the log i ended up with tonight. i'm still running a bit rich. i'll work on it a bit more tommorrow.
my safc hi-throttle settings are as follows
1000 -15
1600 -15
2200 -15
2800 -16
3400 -16
4000 -17
4600 -17
5200 -16
5800 -16
6400 -15
7000 -15
just thought i'd share. any input on the fact that my car boggs until 5k rpm? (full boost around 3k or so) i'm thinking it'll get better when i lean it up a bit
thanks guys
the car doesn't feel especially fast until almost 5000rpm, at which point it takes off very well. i suppose this is my timing, which should be brought up a bit once i'm leaner?RPM(rpm).............SPARKADV(deg)....O2S11 (V).......SHRTFT11(%)
3248..........................14.5..........................0.96..........................0
3328..........................9..........................0.98..........................0
3436..........................4.5..........................0.98..........................0
3564..........................2.5..........................0.98..........................0
3716..........................4.5..........................0.98..........................0
3836..........................5.5..........................0.98..........................0
4008..........................7..........................0.98..........................0
4144..........................7..........................0.98..........................0
4280..........................6.5..........................0.98..........................0
4432..........................7..........................0.98..........................0
4608..........................7.5..........................0.98..........................0
4732..........................8.5..........................0.98..........................0
4872..........................8.5..........................0.98..........................0
5032..........................9..........................0.98..........................0
5172..........................9..........................0.98..........................0
5316..........................9..........................0.98..........................0
5460..........................9.5..........................0.96..........................0
5556..........................12..........................0.98..........................0
5712..........................13..........................0.96..........................0
5852..........................14.5..........................0.96..........................0
5972..........................15.5..........................0.98..........................0
6112..........................16..........................0.96..........................0
6232..........................16..........................0.96..........................0
6356..........................16..........................0.96..........................0
6472..........................16..........................0.96..........................0
6564..........................16..........................0.96..........................0
6676..........................17..........................0.96..........................0
6784..........................17..........................0.96..........................0
6892..........................17..........................0.96..........................0
6980..........................18.5..........................0.96..........................0
1000 -15
1600 -15
2200 -15
2800 -16
3400 -16
4000 -17
4600 -17
5200 -16
5800 -16
6400 -15
7000 -15
thanks guys
and I didn't get to do anything else with it).
. Actually, the larger the turbo, the more efficient it is at producing boost. Remember psi=heat.....airflow=power. The EVO III 16g coupled with the FMIC should give you a lower intake charge temp than you had with the SMIC and the T25.
! which I'm sure is killing me.
