T04B V-Trim Dyno Results
Congratulations to Rocky Pacifico for winning the "Turbo Challenge" T04B V-trim 375-399 whp category!!!!!
1992 Eagle Talon TSi FWD
The first 3 pulls were "untuned", meaning that no adjustments we made on the AFC. All of these dyno pulls were on "Pump" gas, 93 Octane. No additives or race gas. This was all done with stock timing, a conservative A/F ratio and with a low pressure actuator which Rocky recently decided to switch for the high pressure one and send it back to the rollers real soon.
297 whp at 10 psi
335 whp at 16 psi
371 whp at 22 psi
394 whp at 24 psi
Mod List
Bullseye Power T04B V-Trim Turbocharger with 38mm Internal Wastegate and Low Pressure Actuator
Bullseye Power Carbon Fiber 3" MAS Air Pipe
2g MAS
Dejon Tool Race FMIC
650 Injectors
Walbro 255
APEXi S-AFC II
SX FP Regulator
Wiseco Pistons
FPR Stage 2 Cams
PR o2 with External Dump
Custom 3" Turbo-Back Exhaust
BAS Ported 2g Exhaust Manifold
ACT Flywheel and 2600 Clutch
