Resolved How do I replace the coolant temp sensor?
JiveMasterT
1,848
9
Jan 3, 2004
Chest of Westerson, New York
My coolant temperature sensor went bad and I need to replace it and I was wondering where it is and how do I replace it? I tried to get a shop manual but no one around here seems to have one and I really need to do this this weekend. Lemme know! Thanks.
Solution
JiveMasterT said:
alright so i called my autoparts store and they dont have it, so i called up satan and they said that they have one for the gauge and one for the computer? Which one do I need? What is the difference?
edit...
also, the code it threw up from the CEL was...
P0115:
Engine Coolant Temperature Circuit
and my temperature gauge in the car showed dead flat across and my logger showed 172-176 degrees. I don't know which one it would be.
Codes only come from the ECU. The ECU doesn't give a shit what the little needle wiping your nose is doing. You need the one for the computer.
The coolant temperature sensor is on the thermostat housing. The sensor just threads in and out so install/removal is as easy as it gets.
Online, i've gotten listings anywhere from $16 to $35 but generally around $20 or so on average.
Oh a side note.. I got an aftermarket temp gauge because with the front mount my car may have an even higher tendency to overheat (my stock gauge isn't accurate, the logger will show a 220 temp if I use it in the summer occaisionally to check) Is it stupid to leave the stock gauge connected and also use the aftermarket gauge to hook up to that temp probe? Also I got a probe with the gauge, is there a better place to tap it than others? I saw a fitting that would slide in the upper radiator hose, and it sounds like the best way to go at it without having to tap anymore holes. So far compressions etc is good, but I don't want to warp my head if the temps shoot even higher this summer when i'm stuck in traffic and I don't find out until it's too late.
hmm. ok, do you guys thing I could pick this thing up at an autoparts store or do i need to go to SATAN?
rice_rocket said:
They should all be universal, so as long as your autoparts store would carry it, then you should be fine.
edit...
P0115:
m1nd64m3 said:
Then it is the sensor for the gauge. That sensor is the one next to it, and i believe it only has one wire coming off of it(not sure)
wait, the sensor that is circled in the picture is for the gauge? then there is another sensor right next to it for the ECU? I guess I gotta go out there an look at it today. can someone show me a picture of where the ecu temp sensor is? Thanks.
sheesh, this went from being a simple 30 min job to the most confusing thing ever! LOL.
The ECU's temperatur sensor is the bigger looking unit mounted to the immediate top of the original picture.
alright, cool. and that is changed the same way? just unscrew it and then screw in the new one (with teflon thread sealant)? I might just do a tech article writeup for this.
LOL A tech write up for unscrew the old and screw in the new? You should also do one on how to check oil level on the dip stick. :p
you'd be suprised at what people are incapable of :thumb:
but seriously, the tech article would mostly be for diagnosing which probe is bad and how to replace the proper one. ill run some tests tonight or tomorrow and post back here when and if i decide to write the article.
edit...
P0115:
Solution
LOL, thanks for that very discriptive reply. alright, ill go pick up the part on monday and ill post here if i got another question. thanks for all the help everyone.
alright, it's installed, just gotta wait for the permatex to cure over night and then ill do the write up (with pictures!) just because it might be helpful for when someone else has this question...
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
