Questions about head/intake/tbody swap
Turbo98
133
Dec 19, 2002
Oak Lawn, Illinois
I have a friend with a 1g head, intake manifold, and throttle body off of a non turbo. I couldn't get a straight answer from my search, but is this the same as the turbo head/mani/tbody? I read the cooling passages are different on the head but I'm not sure. I'm more than likely getting all these parts for free so any info you guys can give me would be great. If you need any more info just let me know to post it. Thanks guys
Turbo98
The Head off of a Non Turbo 4g63 has a less agressive intake cam that needs to be replaced with a Turbo intake cam, but the exhaust cam is the same on both.
Ask your friend if it is a 2.0
If it is, the intake manifold is exactly the same. The head is the same except for the cams and the throttle body will work, but you might be better off trying to find a 1g turbo throttle body. On the N/T's the intake hose clamped right to the throttle body whereas on the turbo cars the UICP bolted to the throttle body. So like the other guy was sayin you will have to make a custom throttle body elbow that will clamp onto the throttle body and the rest of your UICP. Of course, if you could get it to work with the N/T throttle it will flow more than a stock 1g turbo throttle body because the N/T one is bigger.
Hope that helps.
All the info does help. Thanks alot guys it is greatly appreciated.
:dsm: :laser: :talon:
Thank you!
Turbo98
is the NT throttle body actually bigger? i thought it was smaller. does anyone know the size difference?
  • For sale 2g 2G Mishimoto Radiator
    2G Mishimoto Radiator $175 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 4G63 Valve Cover ( No broken bolt holes or cracks )
    Valve Cover ( No broken bolt holes or cracks )* great candidate for powder coat or paint *...
  • For sale 2g 2GB Manul/Turbo Engine Harness
    2GB Manual/Turbo Engine Harness $150 + shipping & paypal fees* wired for 1G CAS, CAS Included...
  • For sale FIC 1650 High Z Injectors
    I have a set of FIC High Z 1650 injectors. They are in great shape with only 500 miles on them...
    • jking29
  • For sale 2g Misc parts
    Have a few things for sale. Open to offers, located in Toronto Canada but can ship- S90...
    • Bedicine
