5150DSM
Supporting VIP
- 856
- 4
- Jan 5, 2004
Sacramento,
California
All right, here's the deal. I determined that my valve stem seals were shot and that was the reason for my smoking at idle and take-off so I have decided to change them. In searching around and reading the VFAQ and such it seems that this is a long and tedious job, especially if you have to remove the head. The Miller Tool compressor is too expensive at this point and I realistically only have about 6 hours to do the whole job so using the VFAQ method with the home-made compressor is not the best option either. Not having done this on a 4G motor before I don't know the limitations of the common storebought spring compressors and why exactly we can't use them. I saw this compressor at Checkers http://www.partsamerica.com/PartDet...EARCHRESULTS&MfrCode=PBI&MfrPartNumber=648432 and it seemed like a decent possibility to use and keep the head on, of course I have no idea if this work or not but it's only $30.00 so...
Does anyone have personal experience with this particular spring compressor or can an explanation be given as to why I wouldn't be able to use this one. Thanks in advance for any help you guys can offer.
Aloha
Aloha
What a PITA it is to take those turbo's out.
