GRNDSM
Moderator
- 2,421
- 195
- May 16, 2002
Chelmsford,
Massachusetts
I have now budded my head with several people who insist that EVO 16G can benefit from a 34mm flapper upgrade. Well, I will give them the fact that this turbo can definitely use a wastegate upgrade, but it is my contention that 34mm flapper is NOT the way to go!
I am not sure if you can see from the photo, but the machined area (on which flapper sits) is raised ~ ½ above the main casting body. You can also see just how close the stock flapper (30mm) comes to that edge!
A 34mm valve completely covers that machined area! In order to fully utilize that valve you leave a wall thickness of less than 1mm! I am sure that this turbine housing is made from a superior material than the good old 16Gs, but I can not possibly imagine that it would last without cracking for anything more than a few thousand miles, if you make it that thin!
I would not be very comfortable opening this opening much past 30mm. Which brings me to my original point: this turbine housing does not allow you to use 34mm upgrade!
So at that rate, I would only recommend porting it to maximize the stock WG (29-29.5mm). This would be slightly smaller than the largest I would recommend to port out on a 34mm valve (30-30.5mm). But then, you are not going to have a huge obstruction in the way of your exhaust gases. And if this mild porting does not work, I would recommend converting to the exhaust WG, over going to the 34mm upgrade.
Has anyone racked on some serious miles on EVO16G with a 34mm WG AND had a chance to look it over? Can you report on how it is holding up?
