What parts do i need?
SinEclipse
766
Jul 31, 2004
San Diego, California
i am about to put a bigt28 since the t25 is going bad, my question is what do i need when replacing the turbo? (yes i am a noob at this and this will be my first time doing this)
-bigt28
-7cm gasket
-ss oil feed line
that is what im getting so far. also i was wondering do i really need the force performance 17psi wastegate acutlator (sp). also if you have a link to where i can get any other gasket please post it.
thanks in advance for any help.
Oh yea and make sure to get some PB Blaster and spray down the manifold to turbo bolts/stud and turbo to 02 bolt/stud atleast a day before you try and remove the old turbo.
u dont have to get the 17 psi one. ur stock t25 only runs at 12 boost and 11 when it hits the intake. ul be running and increase of 5 boost. i would get some hardpipe intake and probably a new o2 sensor since that will probably break. You might need to upgrade your injectors and ignition, and make sure your BOV can handle 17 psi. and if u do replace it.. listen to nate about the PB Blaster (USE PB AND NOTHING ELSE IT WORKS BEST!) other wise ul be cussing alot. prepare to get bloody knuckles to!
