Quick GReddy EGT Question
RBurroughs
173
May 31, 2004
Frederick, Maryland
I just bought a probe with positive a negative wires. I see that the wire from the greddy, coming from the gauge, is also 2 lines (where it would usually plug into the probe). But these GReddy whiles go into a plastic plug, i guess to make probe installation easy. Anyways, can i just cut the plug off and attach the positive wires together and the negative wires together?
Also side note question, Right now it has the red light blinking, is this because of no signal from probe? i plugged in probe wires into EGT plastic socket thing, but it kept blinking. So im wondering if that just means no signal or it isnt hot enough. I havent drilled the mani to put the probe into yet because i wanna make sure the connection works...
hope this makes sense, hard to describe,
Ryan
Install the probe.
Cut the plug. Stip the gauge and probe wires and use some spade connectors insted. Insulate the connection with some shrink tubing and it will come out clean. As long as there are two wires out the gauge and two out the probe you'll be fine. If it doesn't work, switch the wires.
I am by no means an electritian, but I did stay at a Holiday Inn last night. :laugh:
Just kidding. I installed mine, it's easy, just take your time.
