pboglio
- 1,801
- 90
- May 8, 2004
Palos Heights,
Illinois
For the guys out there interested in quicker spool up on their 16gs for autocrossing or stop light to stop light street driving, try swapping to a 6cm turbine housing. Its good for 400 rpm quicker spool. Did it on my small TD05H-16g with a 6cm port job and 10*clip on the turbine wheel. MUCH better bottom end response, the loss of top end I could not detect. The torque would hit you around 3000 rpm vs. 3400 rpm, could even lug it around 2600 rpm and actually get some power to come out of slow corners. The 7cm was laggy in comparison, NOTHING below 3200-3300 rpm. It basically shifts your entire torque curve down about 400 rpm, very nice for you autocross freaks. I could not detect any choking up past 120 mph. Actually one year Mitsubishi EVO actually ran with a 16g and a 6cm turbine housing.
Sounds crazy but David Buschur did it on his 91 Eagle Talon back in 91-93. He actually recommended it to me when I told him my 16g with the 7cm was laggy back in 1995. I had an automatic and needed the quicker spool for better launching. A nice ported 95 exhaust manifold port matched to a ported 6cm would be IDEAL for an autocrosser. That setup spooled FASTER than my T28 on my 2nd gen, WAY faster.
Quoted out of Turbo & High Tech Performance, September 1997 issue, pg73: "David hand-ported the exhaust manifold and 02-sensor housing while swapping out the 7cm2 turbine housing for a smaller, ported 6cm2 housing for better response....The following year, Dave got educated in a hurry. With an opened-up exhaust (2.5-inch diameter from the turbo back) that eliminated the cat, a larger fender-mounted intercooler, a Marc Hallman manual boost controller, an Extrude Hone-processed intake manifold and an HKS GCC that allowed more precise tuning of the fuel curve, Dave's best time in 1993 was a 12.34 @ 116.72 mph.
"...made history in doing so with an 11.98 second pass that eclipsed 116.36 mph. This was accomplished by installing the 7cm2 turbine housing, swapping on a tubular manifold, fitting an external wastegate and lightening the car 200 pounds."
So, it LOOKS like Dave went [email protected] mph on a 6cm housing, then went all out and swapped back in the 7cm2 housing to crack into the 11's.
The real nice thing about Mitsu turbo's is one V-band clamp, 4 exhaust manifold bolts, and 2 downpipe nuts drops the turbine housing/02 sensor out. For autocrossing it can be done in 20 minutes tops. Head out to a dragstrip and pop the 7cm backin. Total flexibility. Actually I have a spare 6cm housing on hand (bought used for $50, NO cracks) for when I swap to an EVOIII 16g, just in case.
Ahh just thinking of mechanical tunning makes me feel all warm and fuzzy inside ,then I get a splitting migrain because of all the possobilities wich can be used.
