2g Center Console removal
CONSOLE / SHIFTER BOOT REMOVAL
this is done on a 2nd Gen, its alittle harder to do then a 1st Gen.
On a 1st gen you basicly remove your shifter knob and yank up on the boot
____________________________________________________________________________________________
Remove the ashtray/cup holder ( just kinda yank up on it )
There are 2 Screw under this assembly holding the concole to the floor.
2. Un-Screw the shifter knob, and pull up on the boot to dislodge the bushing.
There is a little light thats shines on the ashtray, twist out the socket.
Remove the HVAC/radio trim piece.Pull on it from the top, by the
outside/inside air. There are 2 clips near the top and just retainers at the bottom.
DONT pull on the bottom.
Remove the 2 screws behind the trim piece that are right above the radio.
Remove the 2 screws that Are on each side of the console in the rear seating area
Pull up on the concole a little and remove the wires connected to the lighter and unscrew the light on the lighter and ashtray
Remove the whole concole from the car.
Remove the 4 screws holding the shifter boot to the bottom of the console.
Unfold the flaps that are wraped around the shifter boot mounting ring.
Turn the entire boot in-side-out
Cut the zip-tie that holds the boot to the bushing.
Save the bushing and trim ring.
Turn your new shifter boot in-side-out.
Replace your bushing. (secure it with a new zip-tie)
Wrap the flaps around your Mounting ring.
Turn the boot right-side-out
Reverse the removal prosess
Enjoy!
Boot Examples Ive made for people HERE
www.turboeclipse.com
