Leaking oil from oil filter
nuggets
319
May 28, 2004
hales corners, Wisconsin
Hey,
last nite, i got on my car pretty rough when it was..... moderatly warmed up. it sure did warm up quick though. yes i am probably an idiot for doing this but that is behind me now. i wake up this morning to move my car, and what do i find? a big puddle of oil leaking from my oil filter. I know for a fact this was probably my fault, I would just like to know how to fix it or WHAT the problem is so that I will never do this in the future.
94 talon tsi fwd
88,000 miles
k&n
free mods
b&m FPR
running 18 psi
I had the same problem last weekend. This is what I did to fix it-----Drain oil, pull filter off, get a 23mm deep socket and try tightening the protruding metal thing that the filter fits over (this bolt attaches the oil cooler to the block). Don't over-tighten!, replace filter--fill oil and cross fingers. What led me to this was my filter backing off under boost, my damn oil cooler and filter was hanging on by a thread literally. No leaks since then so i'm assuming this fixed the problem. Good luck :dsm: :thumb:
This is indeed a problem on the 1g's with a water/oil cooler. It's an easy fix though, just don't put it off for too long!
Remove the oil filter, reach up and unscrew the threaded stud that the filter screws onto. Allow the oil to drain from the motor as long as possible. Clean the parts as best you can, check the condition of the O-ring that is situated between the cooler and housing. Upon reassembly make sure the O-ring does not roll, pinch, or fall out of place.
Apply some loctite to the threads and screw it back into the housing. Torque spec is 26-33 ft/lbs, overtightening WILL crush the cooler and mix coolant with oil. Reinstall filter and check the oil level.
MANY Threads on this - your POS Water to Oil Cooler is crushing & letting the Flat Oil Filter Gasket "spit" out of the gap - This can happen at 70MPH & kill a Motor QUICK! Snailpower you & all the other guys like you are sitting on Time Bombs...
For now use only the Mitsu Oil Filter with the T shaped Gasket until you delete the POS Water Cooler, the T shaped Gasket on the Mitsu Oil Filter is less prone to "spit" than the Flat Gaskets found on virtually all other Oil Filters.
Yes - Overtightening the Filter will crush the innards of the POS Water Cooler & cross-contaminate your Oil & Antifreeze - & Guess what - they warm up QUICKLY when this happens...
Here's a recent Thread of many out there that has a fix in it - You really need to go with an Air to Oil Cooler - that is the ONLY TRUE FIX for this problem, anything else is just a bandaid...
http://www.dsmtuners.com/forums/showthread.php?t=125879&highlight=cooler
Vice Grips? Pipe Wrench? It's possible it's Loctited in the OFH from the Factory like the Allen Pipe Plugs that are also in the OFH - It's possible you may have to pull the OFH off the Block & apply heat to breakdown the Loctite.
norice4me said:
i am not positive.... does any one know ware i get get this part from the dealer dont make it any more :mad:
NORICE I'm pretty sure your Oil Filter Bolt part # is VERY similar to the NT Oil Filter bolt part # as the 90 Turbo Oil Filter Bolt is shorter due to the lack of Water Cooler. You can also cut an Oil Filter Bolt made for a Water Cooler & shorten it as I did for use with no Water Cooler.
Trevor90GXT said:
Hey don't the 1990's have the air to oil oil coolers instead of the POS water to oil oil coolers?
Yes - but his Oil Filter Bolt is stripped if I understand him correctly - We are just trying to help him get the stripped Bolt out of his good 90 OFH.
I noticed some slight leaking from my oil filter today after the autocross event. And to make sure I understand what was said earlier in this thread. The problem is the oil filter stud that's not tight enough on the oil cooler? Because when I took off my old filter, I could easily move the oil cooler a good bit (but it was still restricted by the coolant hoses). Does this mean the stud is not tight enough? I only hand tightened the filter until the oil cooler couldn't freely turn anymore.
Another thing, could I reuse my oil since I've only been using it for ~400 miles? I don't feel like paying another ~$20 for 6 quarts of Mobil 1 :p.
As long as nothing contaminates the oil and you use good, clean storage containers, I don't see any problem with reusing your oil. I've done it many, many times when I've had to drain clean oil on an engine.
The problem is your Water Cooler will crush internally & cross-contaminate your Antifreeze & Oil - and/or it'll crush & dump out all your Oil on ground when Oil Filter Gasket "spits" thru gap.
I've looked under my radiator cap and my coolant is still the "ooze" green color, but I'm not sure if that's good enough to proove that I don't have cross contamination. But I'm definitely losing oil through my filter. Right now I'm using the FRAM filter, so should I call up the dealer and order an OEM filter?
I just went to the Chrysler dealer today and asked them for an OEM filter. They gave me a MOPAR part, and when I looked at it, I commented about the fact that it was a flat filter. The guy looked at me like I had a second head growing out of my neck, and talked to "some guy who owns a talon". The guy said that was the part that he uses. If it's not right, I'll just go return it and go to the Ford/Mitsubishi dealer that's right next door :p.
Also, do I necessarily have to drain the engine oil when taking the filter off? If I can get away with just taking the filter off and draining the oil in it (and any that comes out of the stud) into containers, that'd be a lot easier.
