removing the passenger side airbag cover.
97_Raptor
101
Jun 24, 2003
Louisville, Kentucky
How do you remove it, I need to take it out and dye it black.
>unplug the battery
>open up the glove box
>remove rubber stoppers found on both sides, and let the glove box hang loose, or just remove the 2 screws and take the whole thing out (i found taking it out easiest)
>Look up and into the are where the glove box was, you should see a couple screws holding some thin strips of metal. Unscrew them.
>If i remember correctly the airbag should pull out a little ways, and you will see a little red wiring harness. Unplug this, and the airbag should pullout the rest of the way.
I may have forgotten about 1 or 2 screws, but you will probably see them when you get in there. Hope i helped.
