UNDISPUTEDDSM
- 100
- 2
- Jul 17, 2004
NAPLES,
Florida
whats up guys, well i've searched and searched and i've finally have found a ballpark idea as to were i'm going with the 6 bolt i plan on building.....Baiscally my goals are to hit about the 550hp mark if not, more, but still have it as a daily driver (although it will most likely be a weekend warrior). I was hoping, that you guys can go over my parts list and give me any advice that might help me. Another issue is that this will be my first actual build so i dont want anything extremely complex, but i want something that will give me good results as a light to light motor but mostly up top...Heres my parts list..
**keep in mind, i would like the motor to be able to rev to about 7500 or so**
Engine:
*6 bolt block w/crank(what do you guys recommend, stay as a 2.0 or go with a 2.3 stroker?)(should i bore the block?? if so to how much)
*Weisco pistons (i was leaning towards an 8.5 compression, but if i go with the stroker, what do you guys recommend)
*Eagle Rods
*1g head w/ crower springs and retainers (unless you guys recommend otherwise.....should i do some sort of titanium, which i heard are good for high revs)
*3g lifters
*metal oem headgasket (or should i do cometic)
*ARP bolts all around
*BS removed
Fuel:
*850 injectors
*walboro 255 fp
*aeromotive afpr w/gauge
Tubo:
*ported 2g manifold (still debating on a tubullar)
*FP3065 or FP3052 turbo(still reading on this)
*tial 44mm wastegate with tube going back into exhaust
Electronic/Tunning:
*DSMlink (which i already have)
*Eloctronic Boost Controller
Tranny:
*stock tranny for now, with possibly some lsd inserts
Like i said, i would like for the car to be a fast car from light to light, but mostly a monster on the highway. I would like to also rev to about 7500 (if the tranny permits)...i still have some time to save to buy all these but i want to start getting advice. Feel free to add or subtract any parts you might find useful or crappy. Thanks
Engine:
*Eagle Rods
*3g lifters
*BS removed
Fuel:
*850 injectors
*walboro 255 fp
Tubo:
Electronic/Tunning:
Tranny:
