engine wont fire
4g63tsiawd
310
3
Jan 16, 2004
columbus, Ohio
Just got my engine put back in after I installed new rings. My problem is it wont start, if I pull all of my spark plugs and put alittle gas into each hole it will fire for a split second. Things I've done compresion check 140 across the board while engine is cold. Used my buddies ecu nothing. I've got 45psi of fuel at my fpr. I've double check all of my sensor connections. My timing marks are all alined. I'm lost any help please.
Ok I'm stumped, I replaced my injectors out with ones from my buddies car and nothing, used his transistor and nothing. I can activate my fuel pump relay with my datalogger and it comes on. And I'm still getting the 41 injector circuit code.
OK, I'm confused.
Why swap power transistors? What were you trying to test by this?
Does your buddy have a car where you can try swapping your ECU into his car?
Have you taken for ECU out and checked it for damage?
I always find it easier to put questionable parts into a running car rather than putting parts into a questionable car, as long as I'm sure the part in question won't cause damage to the good car.
Perhaps we are missing part of the story that might shed some light on your problem.
What led up to this problem?
Steve thanks for all your help, but I found my problem. I'm a idiot. I had the tps harness connected into the resistor pack harness and vias versa.
