jaksback
- May 22, 2012
san diego,
California
On my 2g 95 esi (yes oooh a non turbo) since i bought the thing the speedo has not worked. I have replaced the gear that is attached to the speed sensor, the speed sensor itself, the speedo cluster, inspected the wiring and as near as i can tell with out pulling the whole wiring harness and starting from scratch there is no reason why it wont work.
the ce light comes on every now and again and sometimes will go off for a vss error code. (nearly failed smog when it came on in middle of test not once but twice) The only part of the speedo that has any life to it is the trip odometer reading and that seems to only turn 1/10 of a mile for about every 10 or more miles i go.
got any suggestions that i havent tried yet (aside from getting rid of the non/turbo and going turbo
thanks in advance.
jak
)thanks in advance.
jak
