Hey guys please help me out[hard starting/gearbox grind]
VexRacing
97
Oct 17, 2003
janesville woo,
I asked this before and only got one response. My problem is with my 1g eclipse gs with the 4g n/t. I have to spray starter fluid in it every time it sits over night, but once i do that it runs normal. until it sits for a while again. I have replaced the coolant temp sensor, and the fuel pump. Ive cleaned the entire throttle body and the tps. I ran an ohm meter on all the fuel system and it all checked out. I need this thing fixed bad i need to sell it. Than my second problem it has a grind in 1 and 3rd it has a new clutch and slave cylinder, and ive bled the system 8 times. I can drive it without having it grind but it seems others cant. Do you think the linkeage isnt adjusted properly. It also has full fresh fluid. I dont know i need this thing figured out its driving me nuts since i dont have any where to park it and i need the cash. Let me know what you guys think. Thanks Vann
i would say fuel pump might be bad even though its new or the filters clog. its a problem in the fuel delivery definitly. the grinding in your 1 and 3rd the syncros might be bad eventhough you replaced clutch and slave cylinder inside the trans something is messed up probly the syncros.
I keep trying to find opinions on this and someone said it might be the fuel pressure regulator. I dont really know how that would affect it but what do you guys think?
