symple
- 125
- 3
- Dec 26, 2002
Rapid City,
South Dakota
So I installed my a/f gauge the other day. . . I used the same power source as my boost gauge (the cluster of wires on the far right of the instrument panel...used for the head-light dimmer and flip up switch) and tapped the 02 sensor wire on the passenger side. At first, I would only get one green light all the way over on the 'rich' side of the gauge. Why? Who knows.
I redid the connection to the 02 sensor, turned it back on and the gauge lit up from red though yellow, and to green, one LED at a time. Then it stayed at the far green light again. Again, Don't know why.
When I shut the car off and tried it again, i got nothing. Not one light.
What am I doing wrong?
I decided to change the positive connection to the fuse box thinking that might help. That's where it is now. I forgot exactly which one I used, but it's one that only has power when the key is at the 'on' position. I tested a 5 amp fuse in it first and it didn't blow it.
On a side note, I used my volt test light and the o2 sensor wire on the passenger side was dead.
My car refuses to idle after it's warm. Could any of this possibly be related?
Any suggestions on how to get this working?
Thanks,
Symple
Thanks,
Symple
