Car runs funny! TOO rich
ApexTsi97
Me and my buddy just installed my AFC 2. Everything is set on 0 which is suppost to make the car run stock. My car is running way too rich? wut do i do? I tried adjusting the AFC like 5-10-15-20% but nothing really happens? Could anyone tell me how that Percentage work on this?? Does this mean that i can run more boost? Currently im running 15 Lbs. Also my car shuts off when i gun it at 1st and or 2nd gear and i shift to nutral? What do i do?
It sounds like you have it installed improperly, go back and recheck everything.
The AFC set at zero, make no adjustment, so it should run the same as it did before it was installed.
But then how come its reading it on my AFC? RPM is working. so it throttle. and so it karman? ALso i set everything back to 0. and my engine light went on? should i worry? wut should i do?
