Abomb4eva
- Jun 30, 2003
Laurel,
alright pretty much my car won't start right now. I got new spark plugs and they work, the battery is also fine. Just curious if anyone would have any ideas on what the problem could be. Thanks.
And yes, you're right, valve timing must be pretty close (prefferably dead on, but it will run if it's close).
). Hold the screwdriver shaft near (about 1/8 to 1/4 inch away) a piece of grounded metal on the car (the bracket with the hole in it on the right side of the exhuast manifold is good spot). Have someone crank the car and watch the screwdriver. If a spark jumps from the shaft to the metal then you know you have spark. You can also buy a spark tester (it looks like spark plug, should be available at any auto store) that way you can do it yourself. If it doesn't have spark, work backwards, check all the ignition cables (spark plug wires), check the coils, etc. (a manual would help you out a lot with these things, Haynes or Chiltons are easy to come by).
But I just don't see how that can be.
I'm going to unplug my temp. sensor and see what happens, I'll let you know. If you're right I won't say anything.
