9D3GSX
- Oct 15, 2003
orlando,
Florida
I bought a 92 tsi awd a couple months ago and wasn't able to drive it because it supposedly had a bad clutch. Well i changed the clutch and all the problems associated with it and now i have a big problem. When i first started the car and drove it, it drove fine, as soon as it went to operating temperature everything went down hill. The car started sputtering and acting like a machine gun. I changed the spark plugs to ngk and the wires to magnecores because the stock setup was pretty beaten up. Now when i start the car the spark plugs get instantly fouled, which means the ecu is dumping out way too much fuel. Even if i put new plugs in, they get fouled instantly. The car has a 255 walbro in it and i have a 3 in downpipe with nothing after that. I was thinking it could be numerous sensors or even the coil pack but i am not sure. I don't want to go spending uneccessary money if you know what i mean. If someone can help me out, I will greatly appreciate it.
