Mitsuclipse91
- Jan 1, 2004
Goldsboro,
North Carolina
Ok its like the title says I try to start the car and it tries but wont turn over.... I cant hear the fuel pump is there anyway to check to see if I am getting fuel or not... also I pull each plug wire out one at a time and try and start the car and there is no spark. I changed the spark plugs (they needed it) changed the coil pack. What do you guys suggest? Should I buy another CAS and replace it too?
)face then its probably all good.
