projectgotsi
- Nov 9, 2003
ok, this does not seem possible to me. I have a 93 tsi 5sp with a 90 engine, timing belt went so I bought a remanned head from National Cylinder Head. Bolted the head on and the car has not ran right sence. After spending a ton of time under the hood and even taking it to the dealer....i took it to a "specialist" with interfearence engines. They checked all the work and told me that I am 1/2 "tooth" off on my timing at the crank. He also said that thier was no way to line it up correct, everything is lined up and correct, but the crank will be 1/2 tooth off either way. They are trying to tell me that the head I got may have been "over milled" and is now too short and is throwing the timing off. I cant belive it. I called Natl. cylinder head and they told me that they have sold over 1 million heads and have never had this problem and all the heads are machined under factory specs. Are we missing somehing? Please help! Andy
