Heeellpp MMeeeee No-Start problem
swing lo
556
Jul 23, 2003
Jacksonville, Florida
Hey guy's and gal's, My car has been running fine for two weeks, and when i changed the radiator hoses and coolant system all together, and now my car won't start. Every sensor is snapped.
The car turns over, and almost start's for about 3 tenths of a second.
I have 150 in each cylinder, spark from all four plugs, and the timing light showed the crank the first notch to the right of 10. It's seems like i'm getting fuel, air , and spark. Can't diagnose it.
Unless i have a monstrous vacuum leak, i can't diagnos it.
what;s a good way to check for vacuum leaks?
Any imput would help.:talon:
What i meant was, every connector of the engine wiring harness is connected inside the motor. I had to change the rubber o-ring on the end of that coolant pipe that connect's to the bottom radiator hose.
If my ecu-caps are leaking, is the ecu shot?
