projectgotsi
- Nov 9, 2003
well, ive spent hundreds of dollars at the dealership and dozens of hours under the hood, but I cant for the life of me figure this out. I Have a 93 tsi 5sp with a 90 engine. Car ran fine till the timing belt broke, so I ordered a remanned head from national cylindar head and bolted it on. Car has not run right sence. These are my problems: Car has no power over 4000 rpm, I start to feel boost, then it just sits at 4-5k with the turbo screaming and the car not accelorating. If I SLOWLY press my foot to the floor, it's better, will pull to around 5500 and then thats it. Also, it starts hard....takes several cranks to start..then when it does, it stumbles to a start then idles like a champ at 800 with NO idle surge, skip or anything. The other problem is my gas milage has gone to crap. Used to get over 300miles out of a tank of gas...no i'm lucky to get 200.00 I took the car to the dealership and they put a new waste-gate cillanoid, turbo gasket, "re-routed vacuume hose" and put a new o2 sensor on (cost me 600.00) car ran smoother but it did not fix the prob. Dealer tried to tell me I may have a cracked piston, but I checked when the head was off and all 4 were clean. I also pulled a compression test and pulled 148-150 across the bord. Last thing I did was put a new fuel filter on and nothing...PLEASE HELP, any tips would be awesome. (dealer also checked all vacuume lines and they were all routed and working, they also put a manual boost gauge on the turbo and it puleld 13.8) Thanks, Andy
