me612
- 1,423
- 5
- Aug 8, 2002
Minneapolis,
Minnesota
well the car started smokin pretty bad today. smokin whitish outta the exhaust. we just recently put a used head from the trader on it, and after that was done, we did a compression test, which was from right to left, 140, 110,130,70. ya i know, not really that good. But the car worked, and it was gettin me back and forth. Well i didn't know if it was the piston rings or the head causing the low compression. So i took the head we had just taken off to Napa, and they basically refurbished it, and it passed their vacuum test. So since i didn't know if it was the head on the car or the rings causing low compression, i figured id just put in some new rings when i put the refurbished head on. well that was the plan, until today the car started smoking. I honestly can not tell if it is anitfreeze or oil being burnt. I know antifreeze is white, and oil is white/blue. but i still can't tell. i've had 2 turbos go once and i swore the smoke looked white, but was told that if a turbo goes, its always gunna be oil being burnt, but i thought it looked white. so anyway, i also had a light pop on on my dash, a little amber light under the boost gauge and i have no clue what the light means. looks like a rectangle with like maybe 4-5 verticle lines in it. also there is some oil on top of the tranny, i can not figure out where the hell its coming from, and u can also just smell coolant when i opened the hood after driving it. So far all i've really done, is wash kinda wash out the engine so maybe i can see better where everything is leaking out of. cuz its leakin into the engine bay, and also must be leakin internally sumwhere cuz its blowin white smoke outta the muffler. In a little bit, imma check for shaft play, and check the IC piping to see if there is crap built up in there, cuz id like to isolate this problem a lil more, and the turbo is a pretty quick and easy check. I'd do a compression test, but like i said, before when we put the used head on, it already had low compression, so what good would another one do. im pretty sure the head gasket is good cuz i just put it on, but low compression kinda points towards a head gasket, but i know its not what caused low compression in the first place because it had low compression from the very beginning. but anyway im just kinda posting up to see if anyone has any input, ill kinda keep posting what i do, kinda use it as a lil log book of exactly what i've done to troubleshoot this b!tch. i dunno, maybe it'll help sumone someday.
