eltracer
- 102
- Nov 23, 2003
Temecula,
I tried to install an autometer boost gauge and it failed! I followed the intructions from vfaq.com. I connected a "T" fitting into the lower vac line of the fule pressure control solenoid valve. I had to replace the original small vac line it came with, with something a little larger to fit the plastic "T". I need some advice.
