dashtz69
- 138
- Apr 16, 2003
Ok, so here's the thing. My car has been running pretty crappy for a while. I got it back to almost running normal, nothing really bad was noticeable. Well then I start hearing this weird when I get on the interstate at around 3K. Like a little whistle. I didn't think anything of it and just kept driving. Well now that little whistle is getting worse. The whistle is louder and now I cannot get the car over 3K when I am at or around WOT. If I accelerate slowly I can get over 3K, but if I am on it it just won't go up and it doesn't accelerate. I don't know if it has been progressively been getting worse or if it just because we are having a cold week, but it's really bad now. It does happen around 1 psi in second, and in the other gears it will get to around 3 or 4 before this noise starts to happen. If I drive really carefully I can get around without the noise, but thats pretty hard to do when getting on the interstate. Anyways, I have a Greddy UIP, Type-S BOV, and an Injen Intake. These are the possible scenarios the guys at the shop gave me -
1. Turbo is going bad. The more I think about it, i can understand this. It spools, but not all the way like it used to, unless I just can't hear it under the noise.
2. Vacuum leak somewhere with the BOV. The guy at the shop for some reason or another thinks the top line from the BOV to the intake manifold is leaking. How would I check this and/or fix it?
3. Another guy at the shop said that there is a little sensor in the stock air box with a wire running to it, and when I put the intake on this was left off and now it is not reading air correctly. I have no idea what he's talking about as I don't remember anything like that when I took the intake off. but maybe I missed something?
4. Maybe the Intercooler pipe is slipping off or something, but I already had it come off once before and it shut the car off and idled like crap when I restarted it.
If anyone has any other possible ideas or thinks one of the above may be correct, please let me know. If it's the turbo that's not all bad I guess, but I just hope my engine isn't totally screwed. I hate to bring it up, but could it be crankwalk? I don't know much about it, so I'm not sure of the symptoms. it still drives fine, and the clutch seems to engage consistently. Also, if I do stay on it, the boost will get to 10. But that is it. It used to be around 13. Well that's all I can think of now. Hopefully I gave enough info. Thanks a lot.
) and it wouldn't rev past like 2k and ran like absolute shit.
