zx11
- Nov 1, 2003
I am experiencing a really harsh ride over slightly bumpy roads and am getting a banging noise from the front end even at slower speeds. Also noticed that when I back out of my driveway I get the same thud when the front wheels move from the driveway to the street (there is a slight drop from the driveway to the street. I replaced the front and rear struts with KYB AGX's about a year ago (I also replaced the top mounts for the front and used the stock springs) and have them turned to the softest setting. The problem started about a month ago. Not sure what is causing the problem - checked the ball joints for play but they seem OK. Are the lower control arm bushings my problem? If it is the control arm bushings, where can I get rubber replacement bushings - I don't want the urethane bushings.
Any input would be appreciated - did a search but can't seem to find anyone with a similar problem.
Its a '93 AWD Talon w/ 105K miles - I am the original owner. Its all stock except for the KYB struts.
