Fluttering...
Earley
50
May 30, 2003
Ok, I have never herd of this, So i am coming to yall for help..Here we go.
When I hit around 3500 RPM and/or 10PSI, I hear a loud fluttering sound, and it only does it when im building boost. I have checked, rechecked every hose. Everything is good and tight, Even done a pressure check. No leaks. I think it could be the plug wires failing at higher RPM's, but im not sure. It didnt do it till after the recent fuel pump rewire.
Mods: Fuel Pimp rewire, MBC, hacked air can, 7 CM housing, K&N, 1 step colder spark plugs. (NGK)
Thanks Everyone who helps!
  • Wanted 2g ABS - Left side harness brackets
    Looking for the metal brackets for left side ABS wiring harness. Sensors not needed
    • Justin DuBois
  • For sale 2g 2GB CAS Assembly ( Complete )
    2GB CAS Assembly ( Complete ) $85 + shipping and paypal feesYou must be registered to see element.
  • For sale 2g 2G Clock Spring, Wiper Stalk, Turn Signal Stalk
    2G Clock Spring, Wiper Stalk, Turn Signal Stalk $35 + shipping and paypal fees* removed from...
  • For sale 4G63 2G Cylinder Head
    2G Cylinder Head $250 + shipping and paypal feesYou must be registered to see element.You must...
  • Free 4G63 1G /2G ECU Connector
    Came with a parts car, 1GA Talon with a 2G ECU. Some wires look cut and spliced. I have no use...
    • Badge023
