JRod
- Nov 20, 2003
Lubbock,
I just installed a new intake pipe on my Laser turbo. Everything went in fine, hooked it all back up like it was, and took her for a test drive. No leaks, everything seemed fine until I hammered the loud pedal. Boost guage immediatly pegged to 25 psi. I have a Blitz SSBC, and last night when I drove the car everything was as usual, 9-10 psi with BC off, 14psi low setting, 18 psi high setting. Now no matter what on or off it peggs out. I traced all of the BC lines and they are correct, just like they were last night. The only connector that I unplugged today was the MAF, and the only vacumn line I touched was the BC solenoid to Wastegate. I put it back and have checke to make sure it was on there, and even replaced the line to triple check.
Has this happened to anyone else????? I am not new to these cars, been with this one for 6 yrs now, and done everything myself. I have narrowed it down to a leaking WG diaphram, or the BC solenoid shit out in a matter of minutes.
Any ideas???????????
