laserturbo91
- 478
- Dec 1, 2002
Baltimore,
Maryland
i just got done replacing my intake manifold which was leaking, had replaced all the vacuum hoses, replaced both upper and lower IC pipes with ones i knew were in working order, tested my IC in a bath tub, the injector o rings are nice and tight, biss screw/o ring are less then 6 months old, replaced the BOV with a working order one, if i take off the hose going to the actuator then i will build more boost, i do not have a real boost gauge yet, and i know you folks are going to say to get one, but a)i can feel there is not enough power (when 6banger stangs beat you) b)even though the stock "boost" gauge is not a true reading, its still an idiot light and works to some of an extent. i cant really think of much else to why i would have a boost leak. i am thinking possibly something with the ecu, but i am not sure, i also replaced the bcs with another bcs and its still not working right. and also to throw a spin to it, boost came back to me one morning while i was taking a girl home, a few days later i went back away
thanks for any help in advanced,
jeff
jeff
