Ignition fuse blown
guy1innc
30
Aug 19, 2002
I bought a wreck 95 Gs eclipse auto, I got everything on it...radiation...powering ..and all...now i just want to start the car up...I also replace spark plug, oil and oil filter. When I'm trying to start up the car the Ignition fuse would go out. I need help bad.......Let me know
Assuming you have a manual, start pulling fuses for items which you don't need to make the car run. You may have to pull every bulb in the car or unplug those harness connections. Look in the areas where the accident occured. Once running start adding the fuses back in. If that doesn't work buy yourself at least 1 good "short finder" and dig in.
Cheers,
GTM
