In BAD need for diognotice Engine Data bug.
Steinarr
Nov 16, 2003
Hi ..
My :talon: Is having a bad boring prablome where i cant figure it out ..
I think it ´s the data .. but .. i need your diognoice ..
Example:
I go out and start the car.. .. i can start.. but he always almoust starts.
i give him a 1-2 min and try again .. same thing.. .. it´s like he always gets a little and if i keep going.. he gets worse..
Then .. most fo the time if i give him more than .. 2-3 min .. up to 5 ..
he sometimes .. starts like there is nothign wrong.. .. $#%$"
Well .. Before few months ago .. he went totally dead.. and i asked for help here.. on the forum .. and i got pointed to that the computer in my car had buggs.. and 3 filters neded to get chaged out..
I did.. and the car started.. but the same bug was still the.. as i just described..
For the info :
Puling the cal .. makes not different.
Is there anything more i can change in the data.. or am i ####ed..
Becouse if i am .. An icelandic dude in Denmark .. when Danish People
have never seen Eagle tallon .. and noone NOONE . .. has parts for me.
Mister me .. here .. CRYING for help !
Regards.
Steinarr.
Mail me plzz .. or any thing.. that might help me . ..
[email protected]
Example:
I start the car.. .. and it´s like he gest few rounds.. while i´m starting ( gets some gas ) but same time i stop starting.. he´s dead.
If i dont give him one minute mabe .. and .. when i start .. it´s like he gets no gas at all ..
Then .. if a wait .. for mabe .. 2 - 4 minutes.. he just starts.. like there is nothing wrong.. .. and has full power no hard times..( perfect ) i drive him up to 250 km .. with out any hard times.
But .. this start thing has been going on for long time..
Until one day .. when he just got stone dead.. no matter what i did..
Then i got here and i got links from the forum to typical bug in the data.. 3 .. filters.. and i changed them .. and the car got back to it´s old state.. the start bug.
Now he is 99% dead.. .. meaning .. first start.. he gets one round.. about.. the rest.. = dead..
No matter what i do.
-s-
So you are saying that it will start and then stall or the car will not start at all? Like the battery is dead.
when this problem happens does the engine turn over. Will it turn over as long as you hold the key or will the car die even when you are have the key turned to start.
Sounds like your battery or starter is broken. Try getting a new battery from a auto parts store, and look in the classified section for a parts car to buy a starter.
The Battery is New.. full and perfect.
The engine turnes. no bug there..
The thing is the engine is´nt getting any gas..
then if i try starting it .. again .. shitt happens and it just starts..
I have 2 Fuel pumps.. and i have tested.. the power to the
ijectors.. and they are not getting there power.. but then
wholaa.. they get the power.. = data bug ..
As i named.. weeks ago .. the car was 100% dead .. no gas at all
i got this tip here to replace filters.. with in the data.. ECU or what it´s called.... the data bnehid the radio ..
And the car started..
But i always have this same bug tho .. that the engine .. cant count on getting gas... and there for .. maby ... with in 2 3 4 .. stars.. even up to 15 shot starts.. the engine .. just starts perfect.. as it should.
Now i have had my car dead for 2 days and no matter how many times i start it .. with delay ... i now before 1 hour ago .. took the data and worked on it a little.. and set it back in the car.. .. and gave it a few starts.. .. with delay .. and wholaa. .. .. it started.
To morrow .. i whont know .. if it will start..
So is there more in the ECU that has buggs.. that i can replace.. or ?
Regards.
Steinarr.
This .
ECU (central computer) replaced (leaking capacitors)
Did get the car upp and runnig.. but i still have this same start bug..
I´m trying to get it down with words.. =)
Change the computer. Changing the filter capacitors was not enough. That's what happened to me once. Good Luck.
best regards:laser:
