Diz
- 54
- Nov 18, 2002
Fillmore,
California
I'm on the verge of giving up with this car and parting it out. It shows multiple error codes. The datalogger I plugged in shows the TPS at 99% and it doesn't change when the throttle is moved. Most of the temp sensors read about -50-degrees C. Basically, everything is out of whack as far as the sensors go. It barely starts and the plugs are black. It had been running fine and then...
I checked the TPS and it tests fine- I'm pretty sure the other sensors are OK also. The grounds look good.
Any suggestions? I'm about ready to start disassembling this thing to sell the pieces...
Thanks
Thanks
