Tom Sawyer
- 596
- Apr 26, 2002
Portland,
Oregon
My car has had this intermittent ticking practically since new and I've just always had something else to do and never gotten around to fixing whatever it is. It is independent of the motor as it does not speed up or slow down with RPM. Never happens when the car is first started up cold or after the car has been shut down for over 30 seconds and restarted. Usually only at idle but occasionally at low load in gear. I've tried testing the accessories by cranking the wheel completely in idle (no change) and turning on the A/C (slightly quieter ticking). I think it could be some solenoid in the A/C but was just curious if anyone might have experienced this before and had a more concrete answer before I tear it apart. Thanks for your help.
Tom
Tom
. If that doesn't fix it I'll post up again.
