initialRES
- 69
- Oct 27, 2003
Fort Worth,
Ok guys, I tried to search but can't find an answer and I hope you have some ideas.
I have a 98 GSX with intake, joe P manual boost controller, Greddy type S BOV, and a RRE Upper intercooler pipe. When I accelerate in second gear, it will spike to about 20 PSI then just start dropping and by the time I reach 6200 (shift point) it is at about 12 PSI. I can't tell if it does the same in first gear because that gear is so short. In third, fourth and fifth it will spike to 20 or 21 then drop and hold just fine at 16 or 17, wherever I have it set.
I have tried:
- tightening all the clamps and hoses but haven't tried a pressure tester yet. I don't feel like building one, but I will if I absolutely have to.
- Checking all vacuum Lines. All are connected
- I have tightened the bolts holding the turbo and the turbo manifold together.
None of this fixed the problem at all. I don't think it is a boost leak but I have no Idea what else it could be.
I have tried:
Not a good thing to do on a t25, but thats just my experience.
