Turbo Timer Not Working Correctly?
jthomp
129
Oct 8, 2002
Carlisle, Pennsylvania
Hey guys. I installed my TT two days ago and it was working fine, now it seems to have stopped. I'n not sure if it's working correctly. It's a Greddy turbo timer incase that helps. I'll start the car and drive for however long, and the TT never starts to auto-count how long it should run for. About 15-20 minutes down the road it will start counting up, and by the time I get to where i'm going, it's down to zero. When I shut the car off, it shuts off as usual. I don't know if it's not counting b/c i'm not drving hard all the time or what. Any help would be great..
you have it in auto mode. the TT is trying to read how long it should time for which works with you tach, so it goes by revs. switch it to mode 1 i beleive it is or set a time on it. all you need is about 30-45 seconds. once you do that you should be good to go.
best of luck
Right. I want it in auto mode. Is there any reason as to why i can drive 20 miles and it never start counting? I don't know...
