Turbo Issues / Spiking / Need help please
Surferdude
Apr 24, 2003
Toronto,
Ok guys
i just spent the entire day going over everything in my car ...
1st I installed a new boost controller
2nd i replaced my entire intercooler pipe / turbo xs bov with a ic pipe (dejon) with the 1g crushed bov
3rd i replaced all the turbo inlet hoses
i went for a quick test spin
1st gear spikeing 23 / 27 psi
2nd gear spikeine 23 psi
3rd gear spikeing 20 psi
no matter what boost setting i put it on my controller (new) it does nothing) im lost here .
another issue is my car runs rich .. it goes to the full led green on the afc monitor and then the car sort of "grunts" out of steam and looses all power
i have tried everything and im lost
who can help me ? anyone ? can any of you guys at the meet help me ?
im in need
thanks
About your boost spike...If I were you I would go back and double check to see if you hooked up your boost controller right...there are a couple of different ways to hook up your boost controller. If it is a mechanical boost controller(Not electrical) then check your two vaccum lines going to the boost controller. You want those to lines to be as short as possible, the longer the lines are the more likely it is to get boost spike.
Thats about all I can think of right now but if you use the "search' button then I am sure you will find your anwser.
ease,
  • For sale 2g 2GB Talon Wing ( 3rd brake light included )
    2GB Talon Wing $90* pick up only in 08096 NJ * 3rd brake light includedYou must be...
  • For sale 2g 2GB Talon Front Bumper
    2GB Talon Front Bumper $200* pick up only in 08096 NJ * tear on the bottom side, picturedYou...
  • For sale 420A 420a heat shield
    $20 and free shipping. Need gone
    • Stizzydrew
  • For sale 420A 420a parts
    Stock Cam caps, lifters, rockers.
    • Stizzydrew
  • For sale 420A Stock 420a camshaft & cam gear
    Stock 420a camshaft and cam gears. $100 + shipping or best offer. I no longer will be using 420a...
    • Stizzydrew
