doofoo
- Oct 23, 2003
Upper Marlboro,
Maryland
I just bought a 92 DSM Laser AWD recently and just got it all running after replacing the fuel pump and ecu with an eprom unit.
Taking it for a drive today, I put it into 1st gear, no problems.. But when i start to let the clutch out it just grinds.. not moving at all.. 2nd - 5th and reverse work fine.
What is the problem here? Just 1st gear? What will I end up having to replace, and would it be better to go with OEM or just upgrade the gear to a beefer unit while I'm in there?
Thanks,
Mike
Thanks,
Mike
