eclipsegst24
- Sep 12, 2003
My check engine light has been on for about two months now, came on right after i put my intake on. I just got around to getting the codes pulled.
volume air flow sensor(P0100)
barometric pressure sensor(P0105)
intake air temp sensor(P0110)
idle control system(P0505)
I have done a little research by searching forums and have found that these all my be linked to the same problem, either the maf is bad, ecu, or the wiring, and something about a tps. I may have broke something or messed up something when i put on the intake. I was also having a inconsistant idle for a couple of weeks but it has stopped. I am looking for any advice or input from you guys about these codes, and what the problem may be and what i can do to correct this, and get ride of these codes.
