Number1gkid
- Aug 5, 2003
Hi i posted about a month or so ago about a problem i had and i was told to get a new ecu so i did and now 1 of 2 of my problems was solved.The first problem was that the fuel pump was not recieving power.The new ecu fixed that.the second problem is that the injectors arent firing.my mechanic told me that if i take the plug off the injector and have someone try and crank it the light should flash everytime that injector is supposed to fire.well the light does not flash.any help would be much appreciated i really need to get my car on the road.im sure you will need to know this info as well.its a 1990 plymouth laser with a 1.8L and automatic transmission.
