Computers Help!!!
I believe you the years computers are compatible are:
1990 must have a 1990
91-94 are compatible with 91-94
95-96 must use a 95-96
and 97-99 must use a 97-99
I may be wrong but I remember seing something along those lines.
You will probably be better off getting a 97-99, most computer repairs/mods get expensive.
If that's true, then how does the 97-99 use the 95 EPROM for dsmlink.?
I thought you had to change plug order if using a 95-96 ecu with a 97-99.. but that wouldn't affect starting your car, it would just run extremely bad...
