timing problem
tsidude
Jul 13, 2003
When the timing is set to 5* btdc, and I remove the timing plug ground the timing jumps to 13* or more. But the manual says it is only supposed to go up to 8*. I set it just like it says in the chilton manual. Any help would be greatly appreciated!
Warning... I may not know what I'm talking about!!!
Check that your idle rpm is correct. The ECU will advance the timing based on idle speed. A high idle could result in a timing advance of several º's.
Too much advance would make the engine ping [with low grade gas] when accelerating hard. Do you get that?
My idle speed is fast but I can not lower below 1k rpms. It also surges all of the time, have not found a fix yet.
I have cleaned the trottle body, installed egr blockoff plate, checked the biss screw for leaks, I have checked to see if the ISC is still moving but have not tested it with a multimeter yet. The plunger moves about 1-2 millimeters. Does anyone know if that is right, I think it should move more. Also could an intake leak cause a surge?
I would check the ISC...it's so simple to do and it turned out to be the cause of my idle surge
So today I tested the ISC and all the values were between 32 and 35 ohms. Does any one know if this is still good. I have seen a couple specs on this, one was if it is over 30 ohms at all its bad and the other said below 40 ohms is good if the car is warm.
Somewhere in the range of 30~40 ohms means that the coil wires are good, probably. The main purpose of the test is to find out if all coils have 'continuity' which means... that you have a reading on the meter and not 'open'... which would give a reading of 'infinity'.
Sometimes the 'plunger' and the 'seat' have some crud on them and do not seal the air out properly. Also the cold idle valve [which is a mystery to me] lets too much air bypass. . . And yes, ANY air leak into the intake area WILL cause a fast idle condition!
So it could still be my isc? Ill try to clean it. I also think I have a leak in one of my intercooler hoses. Could that cause a surge? I need to make a tester. Does any one have any other ideas?
