a camry problem if any can help
TuRBo'DTWiX
120
May 20, 2003
i dont know if this is even allowed in the forums but i figured it's worth a shot im frustrated.
Well i just bought a 1990 camry v6 from a family friend for $1800...there are some probs though.. he removed the antenna or sumthing? or it was leaking and water got into the trunk i think thats what may have caused this
The power windows, power locks on the driver side work intermittently, brake lights, instrument cluster lighting, and reverse lights don't work.
I have the car manual, i checked all the fuses and the brake light fuse was blown so i replaced it.. still no luck any help would be appreciated
sounds like my mom's 94 camry v6...well evidently all i did was take it to the dealer and said fix it and $500 later it works....peace
i really don't know much about camry's, but check and see if any wires in the trunk aria are corroded or shortin out cause that might of caused the fuse to blow. hope this helps :thumb:
