tach stoped working----help me!!!!!
5810
124
Oct 18, 2002
Knoxville, Tennessee
My stock tach stoped working to day, about two days ago i was coming home from school (4 gear about 3500 rpm)and i noticed my tach go to zero than back and again to zero and back, after that it worked fine,this morning i was warming my car up and the tach worked for about 3 mins and just died (went to 0) and does not work again, What can cause this can some one please help me:cry:
Thank you.
Originally posted by jott5555
screw it get a 10inch carbon fiber tach with a 14,000 watt shift light, now thats extreme jk
I think NOT!!!!
On the other hand, im in the process of swapping trannies auto to 5-speed, are the tachs different, meaning higher red line? Or are they the same?
i think i will try to fix my stock tach,:D
Do any of u know what can cause the tach to go dead :mad: :mad: :mad:
Hey 5810
I got 2 extra 1990 nt tach's they are different than 91-94 If ya want one of my extra's (might fix your problem) let me know Ill give it to ya for next to nothing.
1. Maybe your cluster took a poop replace it
2. Power Transistor took a poop replace it
3. Coil pack maybe the wire sending signal came off or somehow got disconnected replace it
Thats about all i can think of
hey, where is the power transistor located,and what color ,and where the on the coil the wire is located. & another question, the tach signal comes from where the ecu or the coil, thanks.
Coil pack and power transistor is on the drivers side of the fuel rail tucked into that area on the intake manifold. I lnow on the 90's the tach signal comes from the coil pack but am unsure of which wire sorry
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
