Someone Help! Question on crank.
ArticNemesis
1,153
5
Jan 3, 2003
Myrtle Beach, South Carolina
Where are you supposed to measure crankshaft endplay at.???
Also.. the crank shouldn't move back and forth between the clutch and belt side of the engine should it.?
[edit]
this is sick guys.. I push the clutch in and the crank moves so far out, that the crank pulley hits my frame.. It shouldn't move that much period, walking or not(right?).
Something is completely f***ed. I'm not sure if it has started to walk, or if it has already left.
