wiring issue with boost gauge
turbofanatic
119
Sep 25, 2002
New Orleans, Louisiana
ok i just got my autometer boost gauge put in my new eclipse and i'm trying to find a power source. i want it to light up when i turn on the headlights, but i can't find a place on the fuse block under the dash that has anything to do with the lights. where do i have to hook this up at for what i want?
-I don't know about the AutoMeter gauge, does it need power to operate the gauge or just for the small illumination bulb? if it's for a small bulb, why not tap into one of the instrument light closest to your gauge.
do yourself a big favor and go buy either a voltmeter or a multimeter and learn how to use it. You will end up using it a lot, I know I did. To answer your question, I tapped the light switch, so that when you turn on your headlights the boost gauge lights up. I used a voltmeter to find it, I believe it was green with a white stripe(not sure though).
    • eclipsemf
