Rickster
- Sep 30, 2003
OK here's the deal. (The long version)
In Canada and own a 93 Eagle Talon ESI (Canada's Non-Turbo Eclipse) The cars in great condition and totally stock. NO ADD-ONS at all.
About two weeks ago I fired her up in the morning and everything was normal. I drove down the drive-no problem, then as soon as I went to hit the gas to get out of my drive the car almost stalled. That's how fast it started. One Second fine - the next, No Power. So here's where I am now.....
SYMPTOMS:
When Starting Cold - the car starts Rough and idles at about 500rpm. If you try and give it gas it ususally bogs out. After about 5 or 10 mins, once the engine is warm, if you nurse the heck out of the throttle you can get it to rev up. The main problem is below 2000 rpm. Even once you get the rpms up to 3000 as soon as you try and move the car the Rpms drop and you have to floor it to get the car moving. THE CHECK ENGINE LIGHT DOES NOT COME ON.
THINGS THAT HAVE BEEN CHECKED OR REPLACED:
The first mechanic changed the fuel filter,spark plugs, checked the wires, disconnected the catalytic converter and did a compression test, no change. He thought it was probably a sensor and he didn't have the computer to diagnose it. only charged me $100, soooooo.....
At A Mitsubishi DEALERSHIP.....
They checked the sensors on the ECM and found no codes, pulled my dash appart( and didn't put it together right - I love extra screws and lights that flash on and off ) and checked the ECM-no problem, then they drained the fuel tank,checked the gas, fluched the fuel system, cleaned the injectors, and replaced my coil pack. They charded me $600 and STILL NOTHING. and I'm not rich enough to pay $79/hr for them to rip everything apart and replace parts that are not the problem sooooo...
Another Mechanic has re-checked all the things already done - as well as checking for vacume leaks. and Still NO SOLUTION!!!!!
Right now I'm waiting to here back from a 4th mechanic after he checks the fuel pressure, pressure regulator and timing. But if that check out- I'm totally STUMPED!!!!
Has everyone missed something small and stupid!
HELP - I'M AT THE END OF MY ROPE!!!!!!!!
WHEN I DO FIND THE PROBLEM I WILL POST THE SOLUTION - Which annoyingly lots of people forget to do here!
Thanks for any help
Rickster
SYMPTOMS:
Thanks for any help
Rickster
Does anyone know if the ECM would tell them that the timing was out????
